Me_Again
Mar 10, 2016Explorer III
N-Trouble wrote:
Stopped by America's Tire today and they said no problem they install LT tires all the time on trailers. They were pushing the following as it is what they stock and say they install the most of.
BFG Commercial TA
Cooper Discoverer HTP
Michelin LTX M/S 2
Said they actually do a lot of the Michelin's although I don't know I have heard of anyone on this board running them. Lots of reports with the BFG Commercials though.
I know all three of those are in a different class from the Michelin XPS Rib or Bridgestone Duravis R250 (which is what I was leaning towards) but they said they could order them. Really pushing what they stocked however...
I'm thinking with the weight of my trailer however any of the three they stock should be a lot better than what I am currently running.
The best LRE LT235/85R16E or LT245/75R16E are the following.
Michelin XPS Rib
Bridgestore Duravis R250
Both are all steel ply tires.
For a poly carcass LT the Bridgestore Duravis R500 has a two ply poly sidewall where most poly carcass LT's are single ply sidewalls.
I have used both the Rib(6.5 years) and R250(4.5 years now). Luck me, my placard list OEM tires as LT235/85R16E tires.
There is a very large marketing effort around the sub standard ST tires available. Remember, these are a tire type that were designed for causal local service. With little or no change they have found there way onto RV trailers that spend hour after hour on freeways for hour after hour. They carry the the 65 speed restriction to obtain the higher weight rating. Then through some new kind of magic, some manufacturers are have raised the speed restriction at higher numbers without decreasing the corresponding the wait ratings. Tire by convention for years used industry standard weight/speed relationships.
ST tires do not follow long establish industry standards and are tested at reduces standards. Why, they do not normally carry passengers.
UNBELIEVABLE! But the dirty little secret of the RV industry.
Chris
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
