Does anyone have any information from the tire manufacturer why we should use trailer tires instead of truck tires on trailers? If all the side wall ply and tread ply are the same, what is the differe...
That's pretty tight. It's too bad you've already bought the LT235/85R16 tires as there's also a LT245/75R16 Michelin XPS Rib that has the same load rating but is about 1.6" shorter in diameter (32.2" versus 30.6"), according to the spec sheet. Any chance of swapping them???
