John_Joey's avatar
John_Joey
Tire tread wear.
Is it normal for tires on a 5'ver to wear evenly across all threads. Or, because of scuffing and being ST's will the outside threads wear faster then the center. Giving a slight "football" appearance.
  • I've never had ST tires on my trailers. The LT's that I use wear evenly and the current ones are almost 4 years old and still look new.
    ST tires rarely wear much in their life unless there is a problem, usually alignment or camber. If you're seeing "rounded" tread on all your tires, you could be over inflated. If you see it on only 1 or 2 tires, you're probably looking at tread separation. Not saying it's =not= wear, especially if you have situations where you have to make very tight turns frequently but, IMO, you're looking more at tire issues than wear.
    Lyle
