psford
Oct 29, 2014Explorer
Tire Wear
Friend has a Montana fifth wheel with some unusual tire wear . The outside edge on one tire on each axle has worn almost down to the cord. The two worn tires are on opposite sides from one another. Th...
donn0128 wrote:Exactly what I would do and don't forget to balance the wheels also. Forget going to an RV dealer they won't have the equipment to do a proper alignment or the knowledge..
Cheap Chinese ST tires, and bend axles or spindles are the prime suspects. He needs to install some quality LT tires then go find a commercial trailer shop that can do axle alignments and have it gone through. OH and don't forget the crappy plastic bushing used on the spring eyes. Replace those with real bronze bushings while he is at it.
