Friend has a Montana fifth wheel with some unusual tire wear . The outside edge on one tire on each axle has worn almost down to the cord. The two worn tires are on opposite sides from one another. Th...
I had installed wet bolts on my trailer to correct the tire wear problem also. Still wore tires. Took apart aging for another look after about 4,000 miles. I ended up replacing the springs as the eye in each spring was found to be egg shaped. New shackles, springs and to be safe new wet bolts. Now have well over 20,000 miles on trailer with now more tire problems.
