psford
Oct 29, 2014Explorer
Tire Wear
Friend has a Montana fifth wheel with some unusual tire wear . The outside edge on one tire on each axle has worn almost down to the cord. The two worn tires are on opposite sides from one another. Th...
SH wrote:There are three aspects to aligning trailer axles. Tracking, which is how square the axles are to the frame. Toe, how much the wheels or wheel is point toward or away from the opposite wheel on the same axle. Camber, a measurement of how vertical the wheels are, tipped in at the top or tipped in at the bottom. A quality alignment will check and adjust all three of these measurements if needed.
So....I have not read many posts on the Correct Track alignment system. Does anyone have this and/or have any reports on how well it does or doesn't work?
