cruz-in
Nov 25, 2013Explorer
sorry I am confused. From tire rack:
"Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86""
So seems to me the 235 and 215 respectively are indeed the tire's width (in mm)....am I mising something....
"Section Width
P225/50R16 91S
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
