dryfly wrote:
cummins2014 wrote:
dryfly wrote:
I'm interested in a TireMinder i10 TPMS system. If you have one of these I would appreciate your comments as to it's reliability and ease of use. Is the display fairly easy to see in the sunlight?
thanks
For what its worth , a friend got rid of his TireMinder , and went with TST 507. Not sure what the reason was The TST 507 is the one I went with ,so far so good after a couple years . It seems to be the most popular , and the one I see most recommended . I have the color monitor, and it seems okay in the sunlight , nor sure its ever been in the direct sunlight.
I have an old TST that needs replacing. I would like info from someone who uses the TireMinder. $200 difference in pricing on the 8 transmitter systems. If the TireMinder has issues this is negligible.
Wow !! $200 difference , I paid like $180 for the 507 on sale, with 4 non flow thru sensors . The non flow thru sensors were also on sale at the time for $40 a pair, I should of got 4 more for the truck, would have been into it $260. Although my truck does have tire pressure readings ,but no warning . The reason the price was as good as it was ,was they changed those sensors to a different style, both the flow thru ,and the non flow thru, the price was the same on sale. I believe they changed them on the security part of it. As said its been nearly 2 years now since I both the TST, sounds like they increased in price quite a bit .
I'll ask the friend why he got rid of the Tireminders .
