Curly2001 wrote:
TST507 has saved me three times now. Had a tire with a leaky valve stem on brand new tires and it caught the slow leak so I could get it fixed before any time damage. Second and third times were nails in the tires one with a fast leak and one with a slow leak. Was on the road in Denver and the fast leak happened and I was able to pull over and change times before it hit 65 psi. I was running 80 psi in the trailer tires. Alerted us very quickly.
Saved me money from ruining a tire. Screen is very easy to read and it gives air pressure and tire temp.
Curly
Only reason I mentioned TST is , it sounds like from previous threads on other forums ,that its the most popular. Sounds like the OP likes the price better on the Tireminder .
IMO if you ask about the TST ,you will get a lot more reviews , that has been my observation on previous threads . If ,and when I need to replace ,it will still be with the TST. Like you I like the color monitor, its easy to read, etc.
