danrclem wrote:
I finally got a chance to take a wheel off and it's a T15x6JJ 6 lug. The tires are 225/75 15. I couldn't find a rating for pressure on the rim but every rim I found in this size had a rating for 80 psi so I'm going to go with the E rated tires. It'll make me feel better and they only cost $26 more for a set of four.
Thanks for all of the good advice.
Danny
If it were me, because I've already done it on my 2 RVs is to upgrade your wheels and tires from 15" to 16" and go with good ST E rated tires, I run Maaxis and haven't had any issues but by upgrading, it gave me a little more cushion as far as my load rating of my tires. If you plan on staying at 65mph or slower then the STs are fine, if you think you have to be a speed demon as some then you better get the LTs but again you have to watch the weight rating.
