outback_06 wrote:
Axles are rated at 7500#. Just going by fading memory on actual weight on axle
I'm struggling here to understand how to help you with a specific tire size/load range or a best brand.
Your first post says " I have E rated tires 16" and "Weights for each axle 4050#". IMO times two axles = 8100 lbs total.
Now you tell us the axles are rated at 7500 lbs which may mean 15000 lbs for two axles.
A 16" E tire from DTI may be a ST E which may have a 3500 lb rating or 14000 lbs for two axles.
I'm guessing here but if you have two 7500 lb axles IMO you need the Goodyear G614 G rated tire at 3750 lbs and 110 psi.
Or another tire fast becomming popular on many trailer forums is the Sailun S637 which is a commercial grade all steel ply carcass tire.
Now if your trailer has 8100 lbs on the axles then a LT225/75-16 R at 2680 lbs times four tires will give you 10720 lbs and a big reserve capacity.
Anyone see something I missed on figuring out what actual size tire/load range he has vs his needs ????
