frizfreleng's avatar
frizfreleng
Tires for the Cougar
I have a 2004 Keystone Cougar 278EFS 5th wheel. Loaded (gross?) weight around 8100 lbs. I bought the unit last fall. The tires that came on it are 205 75R 15 load range D. Some oddball brand which I don't recall at the moment. I was reading a forum post that Sailun tires are the go to brand. So I went to their web site but did not find a trailer tire in that size. Got me thinking that maybe my installed tired are not the right ones. Haven't found the manufacturers recommended size. Can anyone help me here?
Thanks, Friz
  • According to the brochure goducks10 posted, your rig was placarded for =C= tires. If you've got D tires on it, you're actually above the factory recommendation. Personally, I see no reason to go any heavier than a D, though an E would be the next step. As donn said, the Goodyear Endurance seems to be doing quite well, though I've had good luck with the late model Carlisle tires and have no problems in recommending them. They're also cheaper than the Endurance. The old go-to tire, Maxxis, is being left in the dust by these newer tires, which are not only enjoying a better rep, but are speed rated to at least 10 mph over the Maxxis, which are still stuck at 65 mph. While I don't tow > 65, I figure that this means there's more safety margin while towing at my usual 62-63 mph tow speed; less heat build-up.
    Lyle
  • Maxxis M8008 ST tires are a proven quality tire. They offer a 10 ply rated
    Load Range E tire. Be sure they are balanced and you should consider metal valve stems.
  • go to a dealer who will sell you the next size bigger and load range G they will handle to load better. I used to have a blow out every time I went camping. went to tire store I shop at and told Gary this is bad, lets do something in the line of over kill. I never had another blow out
  • Correct tire size will be listed on the metal looking tag which is located on the street side near the front of the trailer. GoodYear Endurance ST tires are made in America and seem to have a good reputation based on the comments posted here and other forums.
