rhagfo
Aug 04, 2018Explorer III
BB_TX wrote:CALandLIN wrote:
Michelin does not build 16" trailer tires and none of their 16" LT tires have enough load capacity to replace any of the ST235/80R16E tires.
My Michelin Ribs are rated for about 400 lbs less than the OEM STs. But my 5er only weighs about 12,000 lbs loaded. With 2,000+ on the hitch, that leaves less than 10,000 on the tires. Tires are rated for 3,042 lbs each. Works for me.
I also run LT tires on my 5er, came from the factory with LT 235/85-16 E’s. The 5er has a dry weight of 9,820# and a GVWR of 12,360#, still less than 10,000# on the axles.
They may only be rated at 3,042# ea. but rated to carry that 3,042# at
106 mph! So at 65 to 70 I feel very comfortable at 10,000# that is an 18% reserve capacity at 10,000# on the axles.
Those that run ST’s freak at brushing a curb or hitting a pothole, do you really worry when you brush or jump a curb with your trucks LT tires?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
