Are all ST tires ******?
Maybe not .
But All LT tires are rated to carry passengers .
Higher LT liability means a better tire .
There is a good explanation on page 2 of this topic :
This is very telling as to how much lower the ST standards are in relation to the LT standards .
Further the ST tire has plainly stamped on the sidewall " for trailer use only " .
The LT tire has no disclaimer .
to recap :
the manufacturer is the same.
both tires are 235 ( one is 80 = 80% and the other is 85 = 85% )
both tires are load range E or 80 PSI .
The ST tire is cheaper ( 86% cost ) .
The ST tire has less rubber and cords .
The ST tire weighs 76 % of the LT Tire .
The LT tire only gets a 3042# rating on the LT scale .
The cheaper / lighter ST tire gets a 3402 # rating on the less demanding ST scale .
This is very clear .
Goodyear , the manufacturer , has to build a much tougher tire for LT use such as on our heavy duty pickups .
