I'm planning to upgrade my drum brakes to an electric/hydraulic disc brake setup. Has anyone done the research on which setup seems best or are they on par with each other? Thanks
Klassic, yes my neighbour and I installed them. The only thing with the brake lines is you have to install aluminum angle (1" x 1" x 1/8") across the frame to support them. We used 3 angles and mounted them with the same screws that hold the belly wrap.
