Shaft0201's avatar
Shaft0201
To cover my dry camp needs
Have a 2008 Extreme megalite. After boondocking this weekend I had a couple issues. The 2 12v batteries in there are a few years old and won’t hold a charge (there ready for replacement). Want to replace there with 2 6v batteries, And possibly a separate battery just for starting the generator??? what’s your thoughts on using the genny a few hours a day to charge back up the batteries? I have all LED interior lights but do have the fridge and furnace running all day and night for the kids during these colder NW Trips. TV and a couple lights on throughout the day.
1) My 2 12v batteries went dead 2 times and had to just with the truck
2) would live some sort of alarm letting me know the Genny (Onan 4K microquiet) needs started to charge the batteries before its to late
3) a possible way to make my generator auto start when it senses low voltage level.
4) how to tell if my current converter is doing its job?
  • 1. Get a Voltminder. Connect it directly to the battery and it will give you a accurate read of what your battery level is at. It has a low battery alarm that you can set.
    https://www.amazon.com/VoltMinder-Digital-Volt-Meter-Batteries/dp/B001IQ1XW4
    2. If your draining two batteries in two days you have a significant drain. If you use your furnace batteries won't last long.
    You will need to run your generator longer. Watch your Voltminder and try and keep it between 12.4 and 12.7 when not charging and batteries rested.
    3. Add more batteries. Two group 24 12 volts will have about 170 amp hours, two 6 volts will have about 220 amp hours. If you add two extra batteries to the two you already have you will double the amp hours. You can see you will end up with more amp hours with 6 volts.
    4. Solar would be nice but you will need at least 300 watts to do any good. That will cost you around $1000+
  • #4) when charging a low battery the voltage should steadily climb to 14.3+ volts.
  • The best thing you could do would be to buy a $4 voltage meter from China. Get one with 4 decimal points, so you can see the difference between 12.5 and 12.4 evenly.. you will see 12.56, then 12.54. With that, you will begin to see your requirements and needs, and then you can learn when to recharge, and the benefit from charging for one hour or two hours.
    Those few things will make your life so much better, and all the people around you will be happy that you run a generator only as much as you need.
