cummins2014
Jul 22, 2013Explorer
Just had that problem ,the seal is nearly six years old, and starting leaking ,not holding water in the bowl, cleaned it well with a round bristle brush about the same size in diameter as the the opening, and then with rubber gloves on put a coat of vaseline around inside and outside of the rubber seal, been working fine for the past six weeks. Before it would not hold water for two minutes. I think the key is a good cleaning of the seal itself, which probably does not get cleaned as well as it should with normal cleaning. Anyway it worked for us.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
