Cummins12V98
Jul 26, 2013Explorer III
up2nogood wrote:Cummins12V98 wrote:
Any tricks to keep water in the Dometic/Sealand Ball type toilet?
I posted on my fix on the Sealand, but after hearing about petroleum , not sure if vaseline is good, I will use plumbers grease the next time , but a good cleaning as I posted before ,and some sort of grease . Worked for me ,and that was six weeks ago.
Thanks, I rebuilt mine last season all new parts ball seal spring and all. Worked great until about a month ago. Almost looks like the ball is rotating about a 1/4" farther towards the wall than it should. I guess I need to tear it all apart and clean the seal. I tightened the two screw/bolts with no luck.
hot water sounds like a good Idea after I have cleaned and re assembled it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
