Cummins12V98 wrote:
Get the GY G tires they have been VERY trouble free since 07. Don't worry about your rims run the G's at 85psi that is the lowest pressure on their inflation chart. Weigh your axles look at the chart and you will see you have a safety margin at that pressure. I did the same on our Avion Platinum E to GY G's 5 years never a problem. Several trips from Palm Springs to Phoenix at 75+ mph across I-10.
Contact GY they will help you out changing to the G's.
Yea...85 psi in G614 at your weight is not good advice....that puts you down to 3170 lbs of capacity per tire. You are trying to upgrade, not downgrade your capacity.
IF you have 110 psi rims, then the G614 is a good choice for your existing weight. Run them at 110 psi...despite these charts, Goodyear recommends running trailer tires at the max capacity psi listed on the sidewall...110 psi. IF you don't have 110 psi rims, you may want to consider the 17'5 option as your cost will be about the same or less. And if you go with new rims, make sure your research the approved offset for your specific axles.
The below is the goodyear position on trailer tires....
Excerpt from:
http://www.goodyearrvtires.com/weighing-your-rv.aspx
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up.
