rcpd34's avatar
rcpd34
Too much trailer??
Considering going back to a toy hauler after a brief forage into the Class C world. Looking at a 42' Sunnybrook that popped up on my radar. Would be Rv biggest TH I've had and my first 5th wheel. I have a 2008 2500HD Duramax. Not worried about power, but stability? Is this too much trailer? I'm not worried about the weight police, just reality. No flaming please, just good info. Thanks!
  • I towed my 43ft Raptor with a SRW 2008 Ford F350 for a year but ended up getting a Dually because I wasn't happy with the stability of the SRW truck.
  • Ivylog's avatar
    Ivylog
    Explorer III
    What are you going to put in it? What do you think the total weight is going to be. Hopefully it has brakes on all three axles. I've often pulled heavier with a similar PU but I would not pull this trailer with several toys and my family in the truck. I made the mistake of weighing my load and went out and bought a FL70. There is another 06 in CA for $30K.
  • If you are not worried, go for it. The idea of a big bad 35'+ trailer on a 3/4 ton truck scares a lot of folks on this toyhauler site. The one thing they mention is what you mentioned. Stability. So its really up to you. Everything a 1 ton has a 3/4 basiclly has minus the obivious duals, a leaf spring. The power is the same standard gearing is the same and brakes. Like always the trailer has its own brakes to stop itself.
