My Sabre 5th Wheel is 12'7" and I've got a front AC and Vent Covers that are each about 10". That makes the total height at 13' 5" . Am I going to have trouble with bridges?? Thanks! Ron
If you get off of the interstate then you may be to high. Not all low clearances are marked either, trees for example. Even a bridge marked with a height is not always dependable, some times the sign was put there before they built up the road with new asphalt, or the approach and departure angle may put a long rig higher than the stated road to obstruction height. If it is close go around and use the truck routes in the small towns.
