hoddinr's avatar
hoddinr
Too Tall ?
My Sabre 5th Wheel is 12'7" and I've got a front AC and Vent Covers that are each about 10".
That makes the total height at 13' 5" . Am I going to have trouble with bridges??
Thanks!
Ron
  • Thanks for the tips! I was adding the vent cover to the tape measured distance from the ground, but didn't think about hooking up to the truck for a more accurate measurement. Good idea!
    I added the vent cover(s) and the front AC, which it was wired for, the main AC is lower as it is near the rear of the unit.
  • sch911 wrote:
    Time to measure it yourself. Get a helper, a ladder, a 2 X 4, a level, and a tape measure. Set the 2 X 4 on the highest point, level it out and measure to the ground. Easy....
    Do this with it hooked to your truck for a accurate measurement.
  • I would figure out what the actual height is and not relying on a brochure. Go from there.
  • Time to measure it yourself. Get a helper, a ladder, a 2 X 4, a level, and a tape measure. Set the 2 X 4 on the highest point, level it out and measure to the ground. Easy....
  • timmac wrote:
    Stay on the freeways, that's tall for sure, about a foot taller than most motorhomes.
    Well let's see......how do you get to anyplace useful without getting OFF of the freeways ?? ;)
    Places with a clearance less than 14 feet are supposed to be clearly marked. You are close enough that you will need to be VERY careful.
    I think you should get a long tape measure and be sure what your highest point really IS. In some situations, a couple of inches could make a BIG difference.
    When I was involved with house transports, we would carry two 7 foot pieces of PVC and a coupler. If there was any question, we would STOP and get out the "clearance pipe" and be sure.
    Thanks!
    Ron
    Where are you getting the numbers from ? If the paperwork, that number will INCLUDE the AC shroud . .
  • Stay on the freeways, that's tall for sure, about a foot taller than most motorhomes.
  • The 18-wheel truck trailers are usually 13' 6", so if you are on a road that they use then you should be OK.
