Eycom
Jun 20, 2013Explorer
I'll add DRV, Travel Supreme, Alpenlite and Teton to the list. However, from your postings in the Truck Camper forum, you've indicated that you own a 2500 truck, IIRC. The aforementioned 5ers are heavy. As an example; about the lightest models of those mentioned in the 32-34' range would be a used 05 NuWa HitchHiker II LS, 30.5 RLBG Floorplan (32'-1" Ext. Length), empty pin weight of 1840 lbs, with a GVWR of about 13,500 lbs. If you have purchased your friend's 2001 f350 ford dually with a 7.3 diesel, you'll be right on the cusp of your tow rating.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
