4x4ord
Jun 21, 2013Explorer III
ReneeG wrote:skipnchar wrote:
I would have doubt that very many folks on this forum have owned MOST of the brands they might report as best. I for one don't like to give advice about products I've never tried or had any first hand knowledge about. Here's a link to where you can get information from only folks who HAVE owned a brand and compare one against another.
http://www.rv-coach.com/RV/manufacturers/survey/rate_your_rv_results.html Owners rate their OWN RVs based on a standard list of criteria. Brands with the most responses will no doubt be the most accurate (not influenced by someone with an axe to grind or a "brand lover")
Good luck / Skip
Excellent point Skip.
I have a Citation Supreme which is a well built and very well insulated RV. The only trouble I have had with the unit is that the gel coat is cracking and popping after 10 years. So based on my own experience I would rate a Citation Supreme as one of the best but all it takes is a quick look at some of these other manufacturers to know that the Canadian built Citation Supreme does not come close to a Continental Coach.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 23, 2026
