BugsRLB's avatar
BugsRLB
TorkLift Glow Step Resolution Install
Purchased Torklift's Glow Step Revolution for the RV and we installed them yesterday. Purchased part #A8004 from eTrailer for $641.99. Shipping was only about three days, they were well packaged and arrived safely. From start to finish, taking our time, the DW and I did it in about 2.5 hours. First we remove the old steps. Pretty straight forward. 4-9/16" nuts on carriage bolts. Had to sawzall one bolt out because it was cross threaded during install! After old step removal there are two plates with holes in the 27 3/4" apart attached to the RV that the new steps attach to. We put them in & out of position a couple times to make sure of fit. Our opening is 27 3/4". The steps are 27 1/2". So, we needed to take up 1/8" on each side with a spacer washer we supplied. (I think there is a spacer kit Torklift sells, if you know you need it) We also substituted there 3/4" bolts with 1 1/2" bolts because the 3/4" bolts, after installing 2 flat washers, 1 lock washer and the nut, they were too short. Easy install, sturdy and we think they will be a good addition.
  • This brand of step is on our radar as well. Many positive reviews and I like how they can either be a step or ladder type (if in close quarters such as inside storage).
  • "IF" I were to buy any aftermarket step it would be the Glow step!!! They contacted me and asked if I would test them. I said thanks but I was happy with my steps and felt someone else would benefit.
    I crushed my VERY solid Elkhart Industries steps and replaced with the same but with aluminum steps. I am at 200# and standing on the bottom step it drops only 1/2".
    I used my Motorcycle jack to help with installation!
  • We did our homework and read the pros & cons of different type steps. Yes, they are expensive, but we think they will best suit our needs.
  • Thanks for the great writeup & pics. Wife & I are looking to replace the steps on our Durango and are seriously contemplating the TorkLift steps. I have heard many good reviews.
