Ray-EOD's avatar
Ray-EOD
Torque 380
Bought our first RV today, a Torque 380 toy hauler and looking forward to the RV life and suggestions on what I should do to break the unit in? Any suggestions that would help me get started in the RV world would be great? Best clubs to join ect. Thanks in advance.
Stay safe out there.
  • 2btowed wrote:
    After 2 trailers I found it much easier to fix things before they get loose or break,so I now use clear construction adhesive and run a bead down the inside of every cabinet,trim board,etc,where it attaches to walls,ceilings etc.Might be a little overkill but the FS roads and even I-10 are really jarring on all the inside cabinets.Just ride on the inside down Stoneman Lake Road and the saw dust will come from everywhere on a new trailer or MH.I camped in my dealers lot the first 2 nights and left it there until ALL was fixed.Just a thought if you have to drive a ways to pick it up...
    Yes Sir....Seen that happen before and i will not subject our hauler to that kind of punishment.
  • After 2 trailers I found it much easier to fix things before they get loose or break,so I now use clear construction adhesive and run a bead down the inside of every cabinet,trim board,etc,where it attaches to walls,ceilings etc.Might be a little overkill but the FS roads and even I-10 are really jarring on all the inside cabinets.Just ride on the inside down Stoneman Lake Road and the saw dust will come from everywhere on a new trailer or MH.I camped in my dealers lot the first 2 nights and left it there until ALL was fixed.Just a thought if you have to drive a ways to pick it up...
  • Great advice BigDogF250, thanks. I know the material for the cabinets that you are talking about, I will get some of that.
  • 2nd vote for the short local trip. I took a notepad for making lists, actually ran to the local Walmart Saturday afternoon and picked up lots of the things I needed, spent most of that night installing some of it. Then ordered a bunch of stuff from RV places that following week (Walmart usually has a pretty good RV section but some of it is junk and some things can only be found in RV stores). Also bought some stuff at the campground store, who knew you would need 10 different colored trains for the Mexican Train dominoes set?
    Enjoy the process and think outside the box, there are many ways to solve the same problem. Don't forget to get a roll of that counter/drawer cushion pad, I used a piece between each pan, in most of the drawers (stops the sliding of things) and even in the medicine cabinet to keep my tooth brush from disappearing into the back corner.
  • Thanks bigg-limo, it does help. I also found the RV'ing for beginners, great info.
    Thanks
  • I'd load it up and take it on a short trip over the weekend before going too far. That way you can do a shakedown to make sure everything is good to go. The last thing that you'd want, is to go on big trip right away, and find out that something is not right. Plus by doing that, you get to "learn" all the features of your trailer, and how they work. As far as clubs, I'd be sure to become a Good Sam's member. That's your AAA service for Rvs,...plus you get various discounts. Hope that helps.
