cbshoestring wrote:
I read a couple comments under the video. My favorite:
"Sweet! Now I can finally haul my 40' fifth wheel with my Chevy Cavalier! I just need a hitch, then a 1-1/4" to 2" adapter and then the tow all and I'll be set! I'm just kidding everyone, obviously I would use a Geo Metro as the tow vehicle. You know, better MPG and all..." Backwoods223
As a person who is licensed to pull double/triples, this concept scares the ---- out of me. One more wiggle point, hooked to a vehicle that is too small to handle the weight, driven by someone that is trying to cut corners....just buy the correct truck.
It's actually =less= "wiggle point" than your doubles dolly, as the Tow All Dolly is attached to the TV's frame via the receiver hitch and chains, so there's no wiggle there, whereas your doubles dolly is attached via a pintle hitch and allows for 2 points of "wiggle". Given that a proper towing setup means that the TV stops itself and the trailer stops =itself=, you've now got 2 more brakes for the whole thing, making stopping safer. Given that the same basic engines and transmissions are used in 3/4 to 2 ton trucks, how is the hill-handling power any different? You are, or should be, still constrained by your GCVW anyway. As for length, these dollies actually allow the FW to turn =shorter= than a TT, because the hitch point swings to the outside of the turn, pulling the FW with it.
Lyle
