JIMNLIN wrote:
I see these types of dollys at rodeo/horse show/equestrian events/etc.
Tow vehicles range mostly from a caddy Escalade/Tahoe's/burbs/Excursions on up to a one ton DRW crew cab vehicles.
Most trailers are tandem axle GN horse trailers however one event had several triaxle LEQ units. The newer GN trailers can have a GN ball hitch or a goose pin/regular 5th wheel hitch set up.
My only issue with the set up in the youtube is how beefy is the two chain set up to the truck and what class receiver is required.
IIRC, the chains are hooked to brackets that are attached directly to the frame. I know that the one I saw, had 3 hard-point connections; center receiver hitch and 2 "hard" (not chain) connections to the frame. You can see the yellow brackets in the pics I posted.
Lyle
