john&bet wrote:
720Deere wrote:
Atom Ant wrote:
john&bet wrote:
My opinion is that there should be no such thing as a 1 ton srw. Thier tires are the same so thier contact point with the road is the same as a 3/4 ton. JMHO.
?? Let's take it a step further, let's just eliminate the 3/4 ton. Why de-rate a perfectly good SRW 1-ton with lighter axles and springs ;)
Exactly! The 1 ton SRW is everything that a 3/4 ton should be. With the half tons creeping up on the 3/4, the decision to buy a 3/4 over a 1 ton never made any sense to me. As far as the tires go, most everybody has a 20" wheel option these days and those tires ratings are more in line with what the rear axle is capable of. Not sure what the contact patch has to do with it.
If you eliminated the SRW 1 ton, you would force a lot of people that don't need it into driving a dually. No thanks, I'll stick with the more legally capable version of the SRW truck.
The amount of rubber touching the road is called traction. Traction is used for a lot of things. Besides 3/4 ton were around a long time before the 1 ton srw. 3/4 ton did not evolve from a 1 ton srw. JMHO.
Just not sure where you are trying to go with the traction thing - you might explain more.
I think it was Dodge that first came out with a decent 1 ton SRW pickup back in 1978 or so, and it was the best thing since sliced bread - no floating axle, just a heavy payload and it looked and drove just like every other pickup. I never looked at a 3/4 ton again - no point.
I would think with Ford taking the lead with the F450 in a Super-Duty package, the other truck makers will follow suit in the heavy duty truck line and it won't be too long before the 3/4 ton just fades away, or it just becomes another "heavy half" like they used to be in the 70s and they will start dressing out the 1500s as a the new 2500s or F250s. Look what happened to the F-100 - gone.
The only thing that might kill my theory is the way some states license the trucks - if I remember, 1-tons are taxed different or require a different drivers license in some states.
