Wild Card wrote:
Cummins12V98 wrote:
Bob Bo wrote:
Cummins12V98 wrote:
Truck will "pull it just fine" but with a 20-25% pin that a 5er can easily have I HIGHLY suggest the 3500 LONG BED SRW with AISIN!!! Don't forget the towing package with the pucks and then since you will have the best truck for the job buy the best hitch a B&W. You WILL be more than happy with both.
If you really want the icing add the Factory Rear Air Ride.
The new truck as the 5th wheel prep package/puck's, and the rear air ride
EXCELLENT! BUT does it have the AISIN??? Well worth the $$$. You may want to continue shopping. Nothing wrong with the 68REF but when you are at that level why not get the best possible.
Thats your opinion not fact.
Towing fairly heavy with 3.42 gears(SRW) and the Aisin works much better than the 68RFE which has taller 1st and 2nd gears. The only place the 68RFE is better is the reverse ratio.
Chris
