rhagfo
Jan 20, 2014Explorer III
mcguirehg wrote:
I guess I'm still confused. All the dealers say I'll be fine and the towing manual say Maximum Loaded Trailer Weight (Lbs.) – Automatic Transmission is 12,800 pounds for a f250/350 with 4x4. ?https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/2002_All.pdf
Yes they will,
You likely will be if the F250 has a camper Package, BUT you will likely be over your trucks GVWR. The issue with a 5er is not what it weighs, but how much weight the 5er add in the bed of your truck (Pin weight), That Jayco Eagle has 2,400# of Pin weight DRY, before you put a single pot or pan in it.
It may tow fine and handle the weight fine, but you will likely be over your trucks GVWR, maybe a lot.
The next limits to really watch are axle and tire ratings. While I do tow over my GVWR, I am well within the axle and tire ratings.
It is your choice as to what to do, smaller 5er, bigger TV, or go with what you got.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 16, 2026
