Lantley
Jan 25, 2014Nomad
GAWR=6084
Unloaded axle= 3200
6084-3200=2884 for pin before exceeding axle rating.
If you estimate pin at 2800 that leaves 84 pounds before exceeding axle rating.
Does your F-250 already have a hitch in it? If not you need to add another 200# to the weight of the truck
6084-3200 (unloaded axle weight)-200 (weight of hitch)-2800 pin weight=-116.00
That equates to 116# over your axle ratings. That is with an empty bed and just you and your sons.
Also Bucky has an 07' you are looking at an 09' don't assume the weigh exactly the same.
As I mentioned above trailer appears to be too large. If you really like the trailer consider upgrading your truck. You will be exceeding all the ratings.
Unloaded axle= 3200
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
