calewjohnson
Jul 04, 2015Explorer
lcv800 wrote:
Good morning. My 2015 diesel dually F350 is tow rated at 23,500 with goose neck/5th wheel towing. I pull my 44' Voltage (maximum weight listed at 19,500) without an issue. As I'm sure we all do, I exercise extra caution when towing, leaving as much an interval between vehicles as possible. Despite this, I've still had quasi-emergency stops, but have never had an issue. Well maintained vehicles (brakes and tires especially) are the key. If you're not comfortable, make the transition and put disc brakes on your trailer. Not that cost prohibitive. Have a safe and happy fourth.
Rusty
I have a 2015 F-350 with 4.3 gear ratio with my Voltage 3950....I chose this package because the CCC was actually higher than the F-450...I was not too stressed about the max trailer weight, as I won't be towing 30,000 or ore pounds....
Cale
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
