JIMNLIN
Aug 06, 2015Explorer III
bucky wrote:
Once again the quote monster has reared it's ugly head. NA na, my quote is bigger than your quote. :)
Back to the subject with a question for the OP. Have you actually weighed the coach? Pin and axle weights? Loaded for a trip? Until you do all of this is moot.
Good point...typical thread about weights and safety when the OP doesn't give any axle weight numbers which starts the usual arguing.
The OP combo may handle fine or maybe he simply wants a one ton DRW. If the first is the case just keep on trucking.
If he wants a DRW truck then by all means he should get one as your combo is a danger to his family and everyone on the road. :R
OP needs to give us some actual scaled front and rear axle weight numbers for starters.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
