MFL
Feb 29, 2016Nomad II
If you are saying loaded pin wt 1800 plus 200 for hitch, you would need to know your truck rear axle wt loaded to go camping, all people gear, and fuel. If this rear axle wt was 2500, you could not add another 2000. I am thinking your RAWR is about 4,000? You could not have 4,500 on the rear axle.
What is max tire rating? Could the rear tires carry 4,500 lbs?
I'm guessing on your loaded truck rear axle weight. You would have to weigh it to know. In any case, you can see the problem, with the FW in question.
Jerry
Jerry
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
