- lazydaysExplorerMy current trailer is close to 13k lbs. Been running 265/75/16 tires for years.
- rhagfoExplorer IIIThat is the great thing with my TV, it came from the factory with the Optional Camper package 3500 springs, and 265/75-16 E tires, the bummer is it still has the same VIN sticker as the Non camper package unit 8,800 GVWR and 6,084 rear GAWR. :h It must have been too hard for Dodge to make a different VIN sticker. I still have close to 600# to get to the 6,084 of the VIN (max for the stock tires), in theory my rear axle could be rated at 6,830.
- Ron_NielsonExplorer265's require a 7" wide wheel. That's what the 1 ton SRW wheels are. Fairly easy to find in the junkyards or on Craigslist If 265's give you enough capacity, that's what you need, 1 ton SRW wheels.
- SoCalDesertRid1Explorer IIIf you need more than 3400 lbs load per tire in a 16" wheel diameter, you need 285/75-16E's, which are rated 3750 lbs per tire.
I had custom heavy duty steel 16x8 wheels made that are rated 4000 lbs per wheel. I had to go custom because I could not find any 16" wheel available with a weight rating greater than 3500 lbs, back in 2007. I had them made by Stockton Wheel, in California. - laknoxNomad
rhagfo wrote:
laknox wrote:
1963avanti wrote:
Are any of you towing a 12,000 or heavier trailer using the GM stock wheels and 245/75/16 tires? Any problems related to these narrow rimmed tires?
I have an '02 D'max that I bought with 265's on it, and have continued to put them on since. I picked up about 900 lbs' tire capacity, which puts me just over the RAWR on my tires. I can live with it... :-)
Lyle
245/75-16 have 3,042# capacity
265/75-16 have 3,415 capacity
This is a difference of 373# per tire for 746# extra capacity on the rear axle.
Hmmm, maybe that's why my BFG's kept separating. I'm pretty sure that their capacity was much closer to 3500. Oh, well...
Lyle - 1happyhaulerExplorerMy factoy 98 8 lug gm wheels fit my on my 2003 kz sportsmen sportster
- Me_AgainExplorer III
Irelands child wrote:
They work just fine as long as you ensure that the OD will work for clearance between the trailer body and each other plus have the 3042 pound capacity. Yes, I had used them on an earlier 12K pound 5er for 4 years before trade.
I believe OP is referring to his tow vehicle tires. Stock GM rims will not fit a trailer.
Chris - Irelands_childExplorerThey work just fine as long as you ensure that the OD will work for clearance between the trailer body and each other plus have the 3042 pound capacity. Yes, I had used them on an earlier 12K pound 5er for 4 years before trade.
- SoCalDesertRid1Explorer IIAs long as you're not overloading the tires, there shouldn't be a problem. Many millions of trucks have towed trailers with narrow 235/85-16 tires, which used to be the standard tire size for 3/4-ton and 1-ton trucks not too many years ago.
Lyle
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
