JIMNLIN
May 01, 2016Explorer III
Excellent ideas for using 45 psi pressures in a DRW or a SRW truck when empty.
Looking at manufacturers tire pressure charts show the popular LT235/85-16 E has around 1800 lbs capacity for dual application at 45 psi = 7200 lbs capacity. Most DRW trucks rear axles can weigh in the 3000-3600 lb range so 45 psi is plenty of air pressure.
Same with a non DRW truck. Same size tire shows a 2000 lb capacity at 45 psi = 4000 lbs of capacity.
Non of the tires are under inflated.
Now what we do have to watch for depending on tire size and wheel size and back spacing on a DRW is the dual tires rubbing against each other when using lower pressures for a smoother ride.
About Fifth Wheel Group
