Flapper
Mar 31, 2015Explorer
You may want to consider how you load, also. Putting as much heavy stuff in/on the back of the 5th will help a bit in reducing the pin weight. If you can put the gen. on a tray behind the bumper, that might reduce pin weight by 30-40 lbs, etc. I know, not huge, but you're in the territory where everything helps....
About Fifth Wheel Group
