laknox
Mar 31, 2015Nomad
Don't forget that Biscuit's numbers are at GVW of the FW, so these are MAX numbers. If you load lighter, then they will be less. Best thing is to load up as if you're going camping, then hit a CAT scale and get actual weights. Also, if you can, get separate axle weights on the FW and even side to side.
Lyle
Lyle
About Fifth Wheel Group
