Trackrig
Feb 22, 2017Explorer II
lacofdfireman wrote:
I'm overloaded towing a 10k lb trailer with a duramax 2500? The trailer itself shows a GVW or 9300lbs. Thought the Duramax was good to 17500lbs? No
IF you have a 17,500# GVW, then minus the weight of the truck itself which is about 8,200#, you do have 9,300# left before you get in it or put anything else (like the hitch or the air bags) in the truck.
You might be OK on weight, but I don't think you're going to get it hooked up correctly without modifying the 5th suspension to raise the trailer.
Bill
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
