laknox
Feb 23, 2017Nomad
lacofdfireman wrote:
I bought an 07.5 New body style Chevy Duramax truck and it came with a 6" lift and 295 tires. Basically 35" tires. We are in the process of buying a 2014 Grand Reflection 303RLS and I'm worried about driving out 300 mikes to pick it up because my truck is lifted. My truck has the B&W turnover ball and the guy is giving us his B&W companion hitch out of his truck to go with the fifth wheel. Is it possible I'll get up there to buy this and my truck will be to high for the fifth wheel to work? Also should I put airbags on my truck? The guy that owned the truck before me took the airbags off that he had on.
You will likely have major issues. Short term, find someone to tow the FW home for you. Once home, then start figuring out what you need to do to get things level and safe. FWIW, I heard that some GM lifts require a part to be cut off the front suspension (or transfer case or something), and that can't be put back without replacing the entire part that was modified.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
