- BipeflierExplorer
reluyog wrote:
Bipeflier, I'm 3 feet under in Wyoming, and have a ball/pintle hitch on the Kenworth to pull the second trailer there. It's not a big trip. Otherwise we're 61 feet. Spend a lot of summer days there!
Wow,the pic sure makes it look L O N G.
Be safe. - reluyogExplorerBipeflier, I'm 3 feet under in Wyoming, and have a ball/pintle hitch on the Kenworth to pull the second trailer there. It's not a big trip. Otherwise we're 61 feet. Spend a lot of summer days there!
- nevadanickExplorerWhat makes you think he is over length ? I used to pull two bumper pulls and didnt go where i was too long to be legal. I am now buying a fifth wheel and part of the shopping process is making sure when i pull a trailer behind it that i will be legal length in California.
- BipeflierExplorer
reluyog wrote:
transamz9 wrote:
I ran a dedicated trailer cable from the junction box for the 5th wheel umbilical all the way back to the rear through the belly. I ran a 7way to mine though.
Similar to transamz9, I installed a junction box in the back area of my tow vehicle and run two pigtails to the 5th wheel. I installed completely separate wiring on the trailer in pvc conduit for lights, braking, and cameras for the second trailer. That way the second trailer is completely independent from the 5th wheel electrical circuits. I also run two brake controllers. So a total of 4 umbilical's, two for lighting & brakes, one for cameras, and one 50 amp dc line fused on both ends (large Anderson connector).
So how much over length are you? - reluyogExplorer
Similar to transamz9, I installed a junction box in the back area of my tow vehicle and run two pigtails to the 5th wheel. I installed completely separate wiring on the trailer in pvc conduit for lights, braking, and cameras for the second trailer. That way the second trailer is completely independent from the 5th wheel electrical circuits. I also run two brake controllers. So a total of 4 umbilical's, two for lighting & brakes, one for cameras, and one 50 amp dc line fused on both ends (large Anderson connector). - livy1jadeExplorerThanks guys, that's just the info I was looking for.
- BipeflierExplorerI just fished wires up to the tail lights. Solder and heat shrink all connections. Been working flawlessly for 8 years now.
- Cummins12V98Explorer III
Smart move! - Chad_HeiserExplorerI have done both ways described above. I prefer the method of coming back from the junction box at the pinbox. It requires more wire, but you aren’t splicing into existing wires that might cause other issues. You also want to make sure the hitch you have at the back of the 5er is properly mounted and sturdily built. It not only needs to support whatever you are towing, but it also needs to be built so that it doesn’t over stress the 5th wheel frame. There are a lot of side forces acting on the 5er frame when turning due to the typical long overhang behind most 5er axles.
- transamz9ExplorerI ran a dedicated trailer cable from the junction box for the 5th wheel umbilical all the way back to the rear through the belly. I ran a 7way to mine though.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
