MTPockets1
Feb 07, 2014Explorer
Most always the SRW crowd says it pulls just fine, while the issue should be about "payload" . The max payload regardless is the two tires are rated for only so much; most I am aware of is 3415 lbs per tire at 80 psi. That's 6830 lbs. subtract from that the truck weight on rear axle, hitch, people, fuel, other options, and payload tops is 3000 lbs, and realistically much less. You just can't get 5 lbs of Sh** in a 3 lb bag.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
