larry_barnhart
Feb 09, 2014Explorer
NC Hauler wrote:
BUT...what happens if the connection between the truck and 5er comes unplugged or malfunctions?? I agree with both of you about disk brakes on the RV, BUT, I'm talking about having enough truck towing a very heavy 5er and one loses the braking ability of the 5er...it doesn't matter what kind of brakes you have on the 5er "IF" you lose the ability to make the brakes on the 5er work....THAT's when the EB, the T/H mode using the tranny to help slow one down, THEN the brakes that are on the TV itself...That's what I was getting at. It happened to me, bad thing, it was on a 7% grade downhill.....
My truck and the dinky electric brakes work like a charm, have never had an issue, they work flawlessly........until the cable from the 5er to the truck became disconnected...now, no brakes on the 5er...doesn't matter if they're disk brakes or not....if no connection, your truck now has to stop all this weight..THAT is what I was talking about.....
Agree, one has to have enough truck to stop all that weight, just in case something happens to someone while towing.....like it did to me.
Same deal for us I hooked up in the dark leaving from Page az and checked the brakes as I always do. Going down 17 towards Phoenix with out a problem with the truck holding us back I noticed at the bottom the brake controller was not working. Same thing as yours it worked out because of my goof up.
chevman
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
