MTPockets1
Feb 10, 2014Explorer
2008Wildcat wrote:NC Hauler wrote:
One minute you say everyone has their preference, which is 100% correct, then it appears you get a bit mad by stating, the DRW is the "best thing since sliced bread"..."reeked with sarcasm for sure:)
I could also tell you that 75% of all RV delivers that I see and read about on the cummins forum or the diesel place, use dually's to tow and deliver 5er's with.
Yes, everyone has their preference, just get sick of hearing how a dually is the only way to safely tow a fifth wheel. If you believe everything that is read on here, DRW trucks would be the best selling trucks every year. Not mad, not even sarcastic, just stating a fact. Again, I've had both, and in my experience, the dually is not needed for how I use it.
I see RV haulers every day, most tow with SRW trucks. The CDL required haulers that do haul the extremely heavy 5W's use duallys. The last Grand Design Momentum 385TH that we had delivered came on a SRW 3500 truck, and has an advertised pin weight of 3900lbs. Friver said it towed fine, but he knew it was back there, which, no doubt you would know it was there with DRW also..
I towed my 5vr the first year with SRW. Pin weight was 3400 lbs. With added weight of in bed tool box, hitch, people, I was 600 lbs over my door label limit. The truck towed just fine, stopped fine, but I was over and chose to get the DRW which I am more comfortable with. Fact is, the SRW was overloaded, DRW is not. If your SRW is overloaded it's not enough truck for the payload. Will you get away with it? Probably, but doesn't change the fact. It's physics. Over is over. Over
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
