fj12ryder
Feb 10, 2014Explorer III
afishinado wrote:The weight in the back won't change the pin weight as much as you think it might. When I load our bikes, which weigh about 1200 lbs., it only changes the pin weight 40 lbs. So it just depends on the geometry of your particular toyhauler.
Trying to do my due diligence on the tow vehicle selection. Looking at towing 5th wheel toy hauler... The pin weight is high on them when empty, but with two Harleys on the tail I think it'll be well within SRW territory which is what I really want. Now I need to investigate this 19.5" wheel thing you guys are talking about.
Edit: You guys mentioned 'late model' trucks being better at this than they were.. Would 08-10 be considered late enough model? Looking for one in that year range as I like the GM & Ford diesels they used at that time.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
