bad99ram wrote:
I would think that since a transporter is commercial they have to stop at weigh stations. If they were not within limits they would be in trouble.
Study the federal bridge weight laws! It is very difficult for a pickup to exceed them! This is what the LEO in the chicken coops go by. Look at page 4.3!
http://www.wsdot.wa.gov/nr/rdonlyres/ee2d33c7-e6a0-4c58-9bd9-ae05c003b327/0/vehicleguide.pdfHere is what it says for Washington State, all states and provinces are basically the same.
Legal Weights
Gross vehicle weight (GVW) for a vehicle or a vehicle combination is determined by an overlapping set of three criteria: tire size, axle weight, and the weight table (Appendix 3).
The lesser of any one of the criteria will govern the weight of any axle or axle group.
For help in determining the legal gross vehicle weight, call the Commercial Vehicle Services Office at 360-704-6340.
Legal Weight Maximums
Gross Vehicle Weight 105,500 pounds
Single Axle 20,000 pounds
Tandem Axle 34,000 pounds
Two Tire Axle 500 pounds per inch width,* except**
Steer Axle 600 pounds per inch width
*As marked by the manufacturer on the sidewall. Metric conversion to inches: divide metric size by 25.4 (i.e., 285 ÷ 25.4 = 11.22 inches).
**Fixed steer axles, driver operated, equipped with single tires are limited to 600 pounds per inch width. Other than the steer axle, axles carrying more than 10,000 pounds and equipped with single tires are limited to 500 pounds per inch width. For other exceptions, refer to RCW 46.44.042 Maximum Gross Weights – Axle and Tire Factors.
So based on this with my LT265's I can have 12520 on the front axle and 10433 on the rear axle. I dually with LT235 can have 11102 on the front axle and 20K on the rear axle.
But wait, it says the lessers of the three. So does a pickup default to its "axle weight"! Is that the manufacturers GAWR or the rating of the physical axle? Guess I will have to call the number above today!
You do not see GAWR, GVWR, or GCWR anywhere in this formula!
These are the weight laws that are in place to protect the highways and bridges.
On Edit: I just called the number referenced above and her answer was this applies to commerical vehicles. I asked if she thought a pickup could exceed the weight laws, and she said "you are allowed 20K on a single axle and 34K on a set of tandem axles, so no!" Then she talked about tire width and the formula for steer axles and axles with just two tires, like I posted above! I said I find nothing in the state code about GVWR, and she agreed that it is not there.
So, the weight police exist on forums like this, but not in the world of hauling loads for non-commercial.
Chris
