cummins2014
Feb 17, 2021Explorer
4x4ord wrote:
Your upgrades .... exhaust brake, turbo, additional power and transmission, plus the fact that you've got a dually should allow you to very easily handle a 13k 5ver. I would consider a 13k 5ver a light trailer. If you have a gear that will put your engine at an rpm where it makes 400 HP @ 55 mph you will be able to maintain that 55 mph up a 7% grade towing 13k lbs.
I agree ,but if you have dealt much towing fairly heavy with a 7.3 the ETG's are the limiting factor. I dealt with it nearly the whole time I owned that truck ,nearly 16 years . A stock 7.3 just doesn't have it for a heavier fifth wheel , unless you do some mods. I did a few ,and it did help, but the ETG's were the limiting factor, as said it had it there ,but the ETG's would climb up over 1200 degrees ,and I had to get out of the throttle.
Back when the 7.3 was very popular ,and new, ETG's were always a subject on the forums . Water injection, bigger intercoolers etc to deal with it.
About Fifth Wheel Group
