dieseldan723's avatar
dieseldan723
Towing with Dodge short bed
Good evening,
I have had two GMC short box trucks and used a Pull-Rite sliding hitch with ZERO problems. I am now looking at a new Dodge with a short box. The Dodge is two inches shorter than the GMC's I have previously owned.
I am open to another sliding hitch. Is there any issue with this setup that I should be concerned about?
Thank you all for your great advice!
  • The Dodge 3500 I am looking at does not come with the 5th wheel prep package. I assume this will give me a bit more flexibility on what hitch I can use. In two previous trucks I installed the Pull-Rite myself. I won't be doing that on the new truck.
    Please give me any opinions on which hitches I should be considering. I haven't been in the 5th wheel world for over 10 years! (It's good to finally be empty nesters!)
  • dieseldan723 wrote:
    Good evening,
    Yes ,its a 6'-4" bed , and I have no problems towing my fifth wheel without a slider . My truck is the 2014 Ram Megacab ,same bed length as the Ram crew cab short bed. I have two hitches , my older Reese 18K slider ,that I have pretty much quit using, and the Andersen hitch, which is a fixed hitch, although it does have four different tow positions.
    Having said this ,it will depend a lot on the type of fifth wheel, and the pin box position. My present fifth wheel has some very rounded front corners ,and the pin box extends out a little further then my previous fifth wheel. Although both fifth wheels did not require a slider. Both were towed with the Andersen without issue . Good luck with your choice .
  • LadyRVer wrote:
    I used a slider in a short box and when I slid the hitch back and started to manuver, the pin box caught the tail gate... did a number on it. First time I ever used the slider... before that was super careful in backing/turning.
    What year model was your Dodge/Ram truck and was the pin located over the rear axle or behind the rear axle.
  • I use a pullrite slider in my 98 Dodge Ram shortbed 2500 always clears
  • I used a slider in a short box and when I slid the hitch back and started to manuver, the pin box caught the tail gate... did a number on it. First time I ever used the slider... before that was super careful in backing/turning.
