Thermoguy
Nov 20, 2022Explorer II
emilyjane918 wrote:
Thanks for all your help!
I’m glad I’m doing the research to make sure I’m making my family and other drivers safe. I didn’t know what kind of hitch so I’m glad to hear I need a weight distribution hitch - any particular ones that are best?
I’m totally fine with doing a smaller travel trailer. Would you all recommend 10,000 gvwr max for the weight of the trailer?
Unfortunately just bought this truck and didn’t even think about towing when purchased so it’s definitely a lesson I’ve learned. I’m not looking to trade in for a dually or pay to lower the lift/smaller tires at the moment, therefore I understand a smaller trailer is what I’ll have to settle for. Just need to know what gvwr weight for the trailer I should not go over
I'm not sure what everyone is talking about, I see lifted trucks pulling trailers all the time. Your payload is the key ingredient in understanding what you can tow, however, with the modifications to your truck you have reduced that limit. I'm sure a 5th wheel is out but I do see lifted trucks with 5th wheels, not sure about the 6" lift. Make sure you are looking at trailers with a tongue weight well below your maximum rating. The 10,000lbs is meaningless, because you run out of payload on tongue weight before you reach the max tow weight. You might not be able to find a toy hauler that meets that weight restriction. I know you wouldn't with a 5th wheel, but not sure about a small bumper pull. When you get it, makes sure you have the right hitch, then go easy until you get use to the handling of the truck trailer combo. Happy Camping.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
